The front tube is for the camera, lights and arduino with associated electronics. I plan to have another battery in this tube for everything contained in it.
Weight will not be a problem as I will need to add balast. The motors are brusless 1200kva outrunners.
Here is what I want to know?
1. What battery choice do you recommend as long as they fit in the tube I do not mind size but would like duration of running time around 30 mins or more.
2. For the motors which option is best one battery for all ESCs and motors or one for each ESC and motor. So three in total in back tube.
Plus any other advice you can suggests
Thank you
Al
