Hey everyone, I found this web site that sells aluminum and stainless steel tubing and all kinds of accessories for joining the tubes together. They also have all kinds of attachments and I see a ton of potential in mounting options with what you can get. Looks to be almost if not just as easy as doing a PVC frame, although I'm sure it's more $$$$.
http://www.eztube.com/
Simple Aluminum Tube Framing
Re: Simple Aluminum Tube Framing
Guy's, here's the price list from the company since their web site catalog is not working right now. Not as expensive as I thought
Pricelist 11-30-2010.pdf- (104.34 KiB) Downloaded 700 times
Hi
I am working on building a rov with a aluminum frame. I am planning on using 90º and box extruded aluminum.
Like this http://store.aihalaska.com/index.php?ma ... s_id=22707
I am going through another local company.All of the aluminum I need will cost just under $25.
