Hi, i,m looking to build my first ROV and i was thinking of using one of these Cree lights for lighting. I have used them before and they are really bright. Battery life is good too.
Has anyone used them for lighting?
http://www.ebay.co.uk/itm/High-Quality- ... 887wt_1185
Dave
Anyone using Cree LED torches for lighting?
- bikerbones1968
- Contact:
Re: Anyone using Cree LED torches for lighting?
Hi Dave I see your post is unanswered. I am not sure if anyone has used those light here or not. I am new to the forums and havent seen any mention of them yet. There is one post from Dratsabylgu that details what type works the best for underwater lighting. I am quoting the post below in the event you havent seen it.
"For good lighting you need the correct color and enough light.
If you wanted to use LEDs the the color temp should be 6000 - 6500 K, this is the same color temp as normal daylight.
And you need lots of light so go for something like this http://www.ledssuperbright.com/30w-led- ... -led-p-226
Also very important for filming under water is backscatter, this is the reflection of light on particles floating in the water.
To minimize this backscatter its important to place your lamps so that the reflecting light can't reach the lens of the camera."
Hope this help you out.
Anthony
Anthony
Yes, we are using 3 watt LED flashlight like the URL you posted.
We chucked the flashlight up in the lathe and cut off the back end of the flashlight, connect wires to the lamp and ran them off of the PWM lighting control inside the ROV.
The flashlights where then slid inside of a 1" PVC pipe coupling with a plexi-glass lens.
They work very well. If they are to bright you can slightly opaque the plastic lens.
We bought the flashlights at Sam's Club. They came as a two pack.
Jim
Jim
- IMG_0270 (Large).JPG (89.17 KiB) Viewed 7963 times
- IMG_0268 (Large).JPG (55.57 KiB) Viewed 7963 times
