Frame Flotation Test
ERIEWRECKDIVER
Post by ERIEWRECKDIVER »
Just had a very successful flotation test of my ROV Frame. Still waiting for my props.
First ROV after first Flotation Test 021112.jpg (31.56 KiB) Viewed 4042 times
Alaska Rov Systems
Re: Frame Flotation Test
Post by Alaska Rov Systems »
Nice! Looks like you are building the Seafox Rov. I hope the props come soon!
I just noticed your using electrical tape to hold it together, I would use zip ties instead because it is more permanent. With the electrical tape you will eventually have to replace it as it falls off which could cause problems.
ERIEWRECKDIVER
Yea I am using zip ties. In fact I will epoxy everything in place when I am done. But for now the electrical tape keeps everything in place.
Alaska Rov Systems
Ok thanks for the info. Have fun building and exploring the ocean!
