camera V lap top
Our Eye's under the water.
relicmen
camera V lap top
Post by relicmen »
hi,
need help on this
can somebody please explain to me how to plug my camera to my laptop
and record my dive,and explain the material i need to do so!
excuse my english im french
thank you
Re: camera V lap top
To plug the camera into the laptop you just need a video capture device. I use a Smart TV PCMCIA Video Capture Card (seen below) but the device is going to depend on your laptop. I think most of the newer capture devices are USB anyway so they should work with most laptops. If your camera has RCA plugs it should connect up to most Capture devices but if your camera uses something like BNC connections you may need to find a adapter to make the connections. Most of the capture cards should come with the software to record (which may vary) but I use WinDVR.
This is an example of a USB capture device with RCA connections
relicmen
Post by relicmen »
Thans STEVE,
CAN I ALSO USE A VIDEO BALUNS?
Yes, Your camera would hook to one Video Balun on the Rov, then you would use cat5 cable through the tether as your video cable, then the cat5 would plug into the other video balun topside, and then that balun would hook up the the capture card.
Alaska Rov Systems
Post by Alaska Rov Systems »
I have removed this post since it is no longer applicable.
Alex
Last edited by Alaska Rov Systems on Jan 17th, 2011, 8:13 pm, edited 1 time in total.
Zephyr
Post by Zephyr »
I'm using the EasyCAP software.
Finding the driver for windows 7 was a bit of a hassle, but other than that, it's very, very simple to use.
PaulC
Post by PaulC »
In regards to the use of wireless cameras don't go down that path you will lose the wireless signal as soon as the rov goes under water. Read it on one of the forums somewhere.
Most of the capture devices should come with software and just be plug and play but it might depend on what operating system you are using, be sure to check the system requirements of any device before you buy it.
Paul is right.... a wireless camera will not work underwater, (or if it does it will only work for a few feet at best) this goes for most wireless signals (video, remote control, ect.)
Alaska Rov Systems
I have removed this post since it is old.
Alex
Last edited by Alaska Rov Systems on Jan 17th, 2011, 8:15 pm, edited 1 time in total.
Bored_Engineer
Post by Bored_Engineer »
Hello,
I have been looking at that EasyCAP thing too, and I found a pretty good video on installing the drivers correctly:
http://www.youtube.com/watch?v=Zbdz4HNt ... re=related
Hope this helps, I haven't tried it yet..
cheers
*edit*
I did get this to work on windows 7!
PM me if anyone has trouble getting it setup.
