I been thinking about using h bridges as motor controllers. Ive been looking at some transistor based ones but read that they have much higher power loss compared to mosfets, so I'm thinking about using those instead. Problem is I don't really know much about mosfets :mrgreen: so I was hoping someone could help me with what mosfets I could use to make a controller that can handle about 10 amps (all i really know is they have to have a low on resistance...)
I'm planning on controlling the controllers via a arduino. If ive read correctly then if they are powered directly by the arduino they need to be logic mosfets but if i use transistors or a IC H bridge
between the mosfets and the arduino then I can use any, is that correct?
All of the ones I've looked at have a ground and 1 PWM wire for each direction. Is it possible to modify them/add some more circuitry so that there is only a ground and 1 PWM wire for both directions? (so its like a rc esc/servo). How would I go about doing this?
Also If anyone knows of any schematics for a H bridge controller that they could recommend that would be a great help since I've looked at so many and they all a bit different
Any help appreciated
Philipp
