Controlling Depth
Re: Controlling Depth
Or, if the parts inside the ABS box allow it without problems, fill it with wax or oil (or something else that cannot being pressured).
I with Jim on that, I am using ones from Critical velocity 15 amp bidirectional. commercial rov vertical thrusters are always movingRover wrote:I am also using a PWM variable speed control to adjust the vertical thruster for precise hovering ability.
Jim
Alaska Rov Systems
Thanks for the ideas!
james sowell
which speed controler is easy to get im using the bilge pump moters thanks
On a previous ROV our horziontal thrusters were controlled by relays, but I wanted a way to control my vertical position, so I add a bi-directional speed control I bought from Carls's Electronics...... http://www.electronickits.com/kit/compl ... r/k166.htm
This little kit uses a pot to control speed. I remotely connected the three wires for the pot in my drivers box on the surface. This gave me precise up and down thruster speed.
If you have a PWM signal at the ROV, then a brushed ESC (electronic speed control) is the way to go.
Jim
Jim
- k166a.jpg (37.09 KiB) Viewed 6699 times
Alaska Rov Systems
I like that idea.
