almost finished .....
My rov as of tonight id keep working on LEDs and cam but i ran out of solder (the rat shack is closed sadly
more to come
tomorrow tether floats come in the mail .
more to come
- rov 90% assembled letting the 5200 glue dry
- Photo on 2011-09-14 at 23.51 #2.jpg (101.72 KiB) Viewed 9527 times
- inside relays and Ryobi 12v battery
- Photo on 2011-09-14 at 23.52.jpg (120.51 KiB) Viewed 9527 times
- control case
- Photo on 2011-09-14 at 23.52 #2.jpg (92.84 KiB) Viewed 9527 times
Re: almost finished .....
I see that you have onboard battery. What type and how big are they (AH)? planning to use the same, but I have problems to figure out what type of battery to use.
There from the Ryobi HP612K 3/8 in. 12-Volt Cordless Drill/Driver Kit there 3.75 x 3 x 3 inches is the total foot print( as if it was a cube )
250ft of double runs of cat 5
- Photo on 2011-09-15 at 23.34 #2.jpg (95.37 KiB) Viewed 9495 times
- thegadgetguy
Cool. What are you using for floats?
i have to look in to better Buoyancy methods
- 327580_1836715797775_1236872088_32285863_158448672_o.jpg (108.83 KiB) Viewed 9454 times
As of now I have the to electronic boxes filled with small bags of sand as a temporary cheap solution but I cant decide weather I should fill the boxes with mineral oil, a type of buck lead or leave them empty and fight the air with heavy skids this last option I'm not to keen on doing.
what do you think is the best option ?
i finally got around to doing a price breakdown
2XToysmith Robot Claw $3.99 $7.98
4X 5200 Marine Adhesive $8.99 $35.96
1X jb welds $4.36
6X Attwood Corporation Bilge Pump 500Gph Tsunami $13.78 $82.68
1X PYLE PLCM103 10.2'' Rearview Mirror Monitor w/ Night Vision Camera $69.99
1X Underwater Kinetics 406 Clear View UltraBox with Padded Liner $23.24
1X XO Vision HTC35 Universal Weatherproof Camera with NightVision $23.05
2X Joe Knows Electronics 5mm Clear White LED (25 Pack) $5.99 $11.98
1X 500ft CAT5E 350Mhz Solid PVC Cmr Cable Black $67.79
8X 1/2" 90 Degree Elbow PVC Fitting Connector $.55 $4.40
20X 1/2" Tee PVC Fitting Connector $.80 $16.00
2X 10ft 1/2 sch 40 PVC pipe $6.00 $12.00
1X Intech Range Bucket with 48 Balls $24.99
3X 100ft ¾ hollow braid polypropylene rope $5.50 $16.50
1X Ryobi HP612K 3/8 in. 12-Volt Cordless Drill/Driver Kit $49.99
1X PS2 I/O Converter PSC28A +$30.25 shipping $48.78
Wireless PS2 Controller $22.58
High Power White LED 3W with Heatsink & Driver 3 Pcs. $20.90
shipping $7.98+3.99+ -$30.00 gift card
total= 555.31
not all buys are smart
1X jb welds $4.36
total= 555.31
ERIEWRECKDIVER
Wow, you are off to the races. So where do you plan on diving. Any targets?
ErieWreckDiver
ErieWreckDiver
