almost finished .....
shaneb24
Post by shaneb24 »
My rov as of tonight id keep working on LEDs and cam but i ran out of solder (the rat shack is closed sadly
more to come
tomorrow tether floats come in the mail .
rov 90% assembled letting the 5200 glue dry
Photo on 2011-09-14 at 23.51 #2.jpg (101.72 KiB) Viewed 9528 times
inside relays and Ryobi 12v battery
Photo on 2011-09-14 at 23.52.jpg (120.51 KiB) Viewed 9528 times
control case
control case
Photo on 2011-09-14 at 23.52 #2.jpg (92.84 KiB) Viewed 9528 times
Kjetil
Re: almost finished .....
Post by Kjetil »
I see that you have onboard battery. What type and how big are they (AH)? planning to use the same, but I have problems to figure out what type of battery to use.
shaneb24
Post by shaneb24 »
There from the Ryobi HP612K 3/8 in. 12-Volt Cordless Drill/Driver Kit there 3.75 x 3 x 3 inches is the total foot print( as if it was a cube )
shaneb24
Post by shaneb24 »
250ft of double runs of cat 5
Photo on 2011-09-15 at 23.34 #2.jpg (95.37 KiB) Viewed 9496 times
Cool. What are you using for floats?
shaneb24
Post by shaneb24 »
http://www.amazon.com/gp/product/B001TDGOVG
Intech Range Bucket with 48 Balls
shaneb24
Post by shaneb24 »
i have to look in to better Buoyancy methods
shaneb24
Post by shaneb24 »
As of now I have the to electronic boxes filled with small bags of sand as a temporary cheap solution but I cant decide weather I should fill the boxes with mineral oil, a type of buck lead or leave them empty and fight the air with heavy skids this last option I'm not to keen on doing.
what do you think is the best option ?
shaneb24
Post by shaneb24 »
i finally got around to doing a price breakdown
2XToysmith Robot Claw $3.99 $7.98
4X 5200 Marine Adhesive $8.99 $35.96
1X jb welds $4.36
6X Attwood Corporation Bilge Pump 500Gph Tsunami $13.78 $82.68
1X PYLE PLCM103 10.2'' Rearview Mirror Monitor w/ Night Vision Camera $69.99
1X Underwater Kinetics 406 Clear View UltraBox with Padded Liner $23.24
1X XO Vision HTC35 Universal Weatherproof Camera with NightVision $23.05
2X Joe Knows Electronics 5mm Clear White LED (25 Pack) $5.99 $11.98
1X 500ft CAT5E 350Mhz Solid PVC Cmr Cable Black $67.79
8X 1/2" 90 Degree Elbow PVC Fitting Connector $.55 $4.40
20X 1/2" Tee PVC Fitting Connector $.80 $16.00
2X 10ft 1/2 sch 40 PVC pipe $6.00 $12.00
1X Intech Range Bucket with 48 Balls $24.99
3X 100ft ¾ hollow braid polypropylene rope $5.50 $16.50
1X Ryobi HP612K 3/8 in. 12-Volt Cordless Drill/Driver Kit $49.99
1X PS2 I/O Converter PSC28A +$30.25 shipping $48.78
Wireless PS2 Controller $22.58
High Power White LED 3W with Heatsink & Driver 3 Pcs. $20.90
shipping $7.98+3.99+ -$30.00 gift card
total= 555.31
not all buys are smart
ERIEWRECKDIVER
Post by ERIEWRECKDIVER »
Wow, you are off to the races. So where do you plan on diving. Any targets?
ErieWreckDiver
