My Meager Machine II
Here are pics of my first 4 frames and designs I'm going to be testing number 4 today with everything installed and ready to go. We'll see how it goes.
- First attempt Modeled after the hornet.
http://my.fit.edu/~swood/ROV_2.html - Rov001.jpg (59.99 KiB) Viewed 4830 times
- Scaled down, balance and weight all wrong flipped up side down.
- Rov002.jpg (108.34 KiB) Viewed 4830 times
- Dive motor in the back tipped the unit up and down. And the cup is pretty flimsy not a deep diver.
- Rov003.jpg (90.42 KiB) Viewed 4830 times
- Latest and greatest attempt initial water test went well so I preceded to finish it out. I will post some video as I get it tweaked into shape New Camera and control housings, Adjusted frame style, New dive motor mount set in the center of the unit, New light housings and design.
Added 2 Battery packs for camera and lights to avoid voltage drop problems with both. - Rov004.jpg (169 KiB) Viewed 4830 times
Re: My Meager Machine II
It's looking pretty good... are you using blower motors for thrusters? if so how well do they work?
The motors are just ducted fans for RC planes brushed dc motors that can run around 10v.
I got them from Tower Hobbies http://www3.towerhobbies.com/cgi-bin/wt ... LXSBF7&P=7.
With voltage drop down 100' of tether it works out about right.
