My ROV project
tanner331
Re: My ROV project
Post by tanner331 »
Hi
I have been working on the frame. Here is a picture.
Here is the frame
Here is the frame
Re: My ROV project
I assume that it is aluminum? What did you use for the fasteners at the corners, are those rivets?
Looks cool, It'll be neat to see how it looks when it's finished. 8-)
tanner331
Re: My ROV project
Post by tanner331 »
Those are pop rivets most of the frame. The corners on the base are bolts with nuts so the top can be removed.
tanner331
Re: My ROV project
Post by tanner331 »
Here are a couple of pictures of my latest test. I tested the ballast, camera, and motor.
SoakedinVancouver
Re: My ROV project
Post by SoakedinVancouver »
Considering it is aluminium, you will be adding zinc sacrificial anodes, yes?
tanner331
Re: My ROV project
Post by tanner331 »
I am going to add zinc plates to it.
tanner331
Re: My ROV project
Post by tanner331 »
Hi
I did a test run of the ROV today.It went down to 50ft. The motor and the ballast tank worked perfectly. We forgot the plug for the camera so I don't have ROV view footage.I will post pictures soon.
tanner331
Re: My ROV project
Post by tanner331 »
Hi
We did another test on the ROV the other day. We built the control board and attached all 4 motors. We sent the ROV down to 75ft. The motors worked perfectly at that depth.I will post footage of the ROV soon.
Tanner
Here is our control board.
Here are the motor mounts
derelicte
Re: My ROV project
Post by derelicte »
Very nice, but what is the air tank for?
tanner331
Re: My ROV project
Post by tanner331 »
The ones on the ROV are the ballast tanks. They are used to raise and lower the ROV. The one on the control board is to pressurize the ballast tanks.
