Can't find Propellors
Nautilus
Post by Nautilus »
I've been searching for a couple days now, mostly though on-line hobby shops and no one has them in stock! There appears to be no US manufacturer and orders are only filled roughly once a year by most places. I need three 50mm counter-clockwise and one clockwise rotating prop. Please help!
Re: Can't find Propellors
Try http://www.harbormodels.com/
I use the Robbe 3 Blade Plastic Propeller in 50mm, they have both left and right versions.
-Steve 8-)
Nautilus
Post by Nautilus »
Steve,
Thanks a ton! I just placed an order. :D I also got one shaft/stuff box and a set of wheel collars to play with. I will probably use a prop adapter similar to yours for the other three motors. What do you call the base piece with the tapping hole? I'm a bit leery of relying on epoxy clay to hold the unit together. Now onto finding suitable mounts for the Johnson pump cartridges. No fabricating for me. I wish I had a shop like yours!!
Cheers,
Bret
mrtristanplaysguitar
Post by mrtristanplaysguitar »
About the mounts for the johnson bilge pumps:
Mounts for the motors has always been my biggest problem. Luckily, I found these 2" pipe straps at the plumbing store. They fit perfectly on the 500 GPH motor cartridges. I recommend these if you are needing a way to mount them
This is one of my horizontal motors on my scout class ROV for the MATE competition
tanner331
Post by tanner331 »
here is a sight that sells hobby things
http://www.hobbyking.com
40991
Post by 40991 »
You can also use rc plane props and a spinner. Like the rov kit at inventive Inc. I used rc props one of my rovs and it work't well
Nautilus
Post by Nautilus »
Thanks,
I went with Harbor Models for the props and Tower Hobbies for the mounting coupler. Used a cut, 4mm screw and seems to work like a charm (i still have to test). I also found a perfect piece of pvc and use a dremmel to carve out grooves for a slide and lock (locking tabs were already present on the bilge cartridge). It fits nice and snug
prop 2.JPG (91.18 KiB) Viewed 10150 times
soulreaper
Post by soulreaper »
Nice work :D
GUI
Post by GUI »
Harbor Models
Best place to buy them from.
Mareike
Post by Mareike »
http://www.conrad.de/ce/
They are my favorites, beside many model parts also a heap of electronic stuff. The parcels were in Thailand 4 days after ordering, so speed is no magic with them.
success!
