UUV
Ianth3impler
UUV
Post by Ianth3impler »
Hello fellow nerds. This is my UUV project, the design is pretty basic this was a no brainer to build in CAD and build in real life. Unlike a ROV It’s life isn't easily saved by pulling on a tether but rather how well the code is that I write for it. Here are some pictures of the build. I will go into more depth later on once the electronics tray is finished.
UUV3
UUV3
UUV2
UUV2
UUV1
UUV1
CAD4
CAD4
uuv v11.jpg (55.39 KiB) Viewed 86624 times
CAD3
CAD3
uuv v11 1.png (261.07 KiB) Viewed 86624 times
CAD2
CAD2
uuv v11d.png (125.22 KiB) Viewed 86624 times
CAD1
CAD1
uuv v11 ee.png (79.6 KiB) Viewed 86624 times
asesorplaza1
Re: UUV
Post by asesorplaza1 »
Buenas noches
Un proyecto muy bonito, mantennos informados, por favor
Un saludo
Good night
A very nice project, keep us informed, please
A greeting
Ianth3impler
Re: UUV
Quick update, electronics tray finished working on mounting the electronics and building out the PCB boards. Next mile stone is building the battery pack out of 18650’s.
plate v1.png (57.24 KiB) Viewed 86605 times
Re: UUV
What goal do you have in mind with the UUV? Look likes a well thought of build sofar.
Ianth3impler
Re: UUV
I don't know what I'll do with it yet. Trying to figure out a few things with 3d sonar. Coding is going to be the worst thing for this.
Ianth3impler
Re: UUV
UUV is coming along nicely. Still haven't gotten to playing with programming it yet I’d like to have everything physically built before that. I have been working on converting a fish finder into an altimeter.
Re: UUV
Post by a_shorething »
Ianth3impler wrote:I don't know what I'll do with it yet. Trying to figure out a few things with 3d sonar. Coding is going to be the worst thing for this.
Nerd response level=EPIC
asesorplaza1
Re: UUV
Good afternoon.
You can put some specific link on this "Nerd response level-EPIC", I only find video games.
Thank you for a greeting
Ianth3impler
Re: UUV
I have little updates now. So far I have loaded ROS (robot operating system) on the RPI and have been slowly building the battery pack out of 18650’s. I designed a mast to put the GPS and wifi antenna and 3D printed a mold, however when I cast the mast in epoxy it failed (a lot of lessons learned there!). I have came across a few design flaws that need to be worked out that will be accounted for in the next UUV I build which I have already designed and parts sitting on the shelf. Next UUV will have contra-rotating props, the whole body will be fiberglass/ carbon fiber, and use lead acid 24 volt batteries.
Federica16
Re: UUV
Post by Federica16 »
Hi! some guys and I are designing a drone with a very similar shape to the one you created. Why do you say you want to use carbon fiber? What advantages would you have? Ours is 2 meters long and 0.4 meters in diameter. Do you think it is better in steel or carbon fiber?
