UUV
- Ianth3impler
UUV
Hello fellow nerds. This is my UUV project, the design is pretty basic this was a no brainer to build in CAD and build in real life. Unlike a ROV It’s life isn't easily saved by pulling on a tether but rather how well the code is that I write for it. Here are some pictures of the build. I will go into more depth later on once the electronics tray is finished.
- UUV3
- 122101571_296257231806546_4663520419418062103_n.jpg (21.33 KiB) Viewed 86617 times
- UUV2
- 122042424_2762007337461331_3345479698753519315_n.jpg (17.34 KiB) Viewed 86617 times
- UUV1
- 122102486_354954789257428_5176431462292007191_n.jpg (13.69 KiB) Viewed 86617 times
- CAD4
- uuv v11.jpg (55.39 KiB) Viewed 86617 times
- CAD3
- uuv v11 1.png (261.07 KiB) Viewed 86617 times
- CAD2
- uuv v11d.png (125.22 KiB) Viewed 86617 times
- CAD1
- uuv v11 ee.png (79.6 KiB) Viewed 86617 times
asesorplaza1
Re: UUV
Buenas noches
Un proyecto muy bonito, mantennos informados, por favor
Un saludo
Good night
A very nice project, keep us informed, please
A greeting
Un saludo
Good night
A greeting
- Ianth3impler
Re: UUV
Quick update, electronics tray finished working on mounting the electronics and building out the PCB boards. Next mile stone is building the battery pack out of 18650’s.
- 122183979_3386005244853470_3252779369179500165_n.jpg (17.12 KiB) Viewed 86598 times
- plate v1.png (57.24 KiB) Viewed 86598 times
- 122271207_1667682253437282_3311416284271676690_n.jpg (15.56 KiB) Viewed 86598 times
- 122502204_385036779575489_204713998020905492_n.jpg (334.42 KiB) Viewed 86598 times
- 122257245_657683558268536_7248962646996832871_n.jpg (122.91 KiB) Viewed 86598 times
- Ianth3impler
Re: UUV
I don't know what I'll do with it yet. Trying to figure out a few things with 3d sonar. Coding is going to be the worst thing for this.
- Ianth3impler
Re: UUV
UUV is coming along nicely. Still haven't gotten to playing with programming it yet I’d like to have everything physically built before that. I have been working on converting a fish finder into an altimeter.
- 125121443_645088946129748_2805299988412028261_n.jpg (92.48 KiB) Viewed 86406 times
- 124275793_924095991452818_2024447651023523934_n.jpg (379.44 KiB) Viewed 86406 times
- 124046655_3377994115569115_8425227316502322080_n.jpg (377.94 KiB) Viewed 86406 times
- 124079958_682435495744429_1999949288038237107_n.jpg (87.21 KiB) Viewed 86406 times
Re: UUV
Nerd response level=EPICIanth3impler wrote:I don't know what I'll do with it yet. Trying to figure out a few things with 3d sonar. Coding is going to be the worst thing for this.
asesorplaza1
Re: UUV
Good afternoon.
You can put some specific link on this "Nerd response level-EPIC", I only find video games.
Thank you for a greeting
- Ianth3impler
Re: UUV
I have little updates now. So far I have loaded ROS (robot operating system) on the RPI and have been slowly building the battery pack out of 18650’s. I designed a mast to put the GPS and wifi antenna and 3D printed a mold, however when I cast the mast in epoxy it failed (a lot of lessons learned there!). I have came across a few design flaws that need to be worked out that will be accounted for in the next UUV I build which I have already designed and parts sitting on the shelf. Next UUV will have contra-rotating props, the whole body will be fiberglass/ carbon fiber, and use lead acid 24 volt batteries.
Federica16
Re: UUV
Hi! some guys and I are designing a drone with a very similar shape to the one you created. Why do you say you want to use carbon fiber? What advantages would you have? Ours is 2 meters long and 0.4 meters in diameter. Do you think it is better in steel or carbon fiber?
