Scout Mk1
- Ianth3impler
Re: Scout Mk1
Got to test a motor today in freshwater and salt due to having a freshwater aquarium and a reef tank. My most important project is getting the end flanges cast everything else is just waiting for stuff to come in the mail. I have a pretty good idea on how I’m going to waterproof the through hulls. Battery wise I will be making my own 3 cell 17000Mah battery from 20700 cells more to come on that. I will post as much as I can over the next week but it will probably be slow.
- 3D printed flange to test fit it for stungness before its casted.
- flange test fit.jpg (41.62 KiB) Viewed 8999 times
- water change on the reef tank today do I tested the motor in saltwater, worked out fine.
- saltwater test.jpg (40.59 KiB) Viewed 8999 times
- wife would kill me.jpg (46.04 KiB) Viewed 8999 times
- 3s 17000Mah battery made from these.
- 20700.jpg (33.1 KiB) Viewed 8999 times
- Test inside my Freshwater tank.
- test1.jpg (32.38 KiB) Viewed 8999 times
- Best connectors ever!
- awesome connector.jpg (27.27 KiB) Viewed 8999 times
- Test setup. Controller is just to send PWM to the ESC.
- test setup.jpg (50.64 KiB) Viewed 8999 times
Re: Scout Mk1
https://www.ebay.com/p/22006058790?iid=274115919207Ianth3impler wrote: In the mean time I have not found any viable (cheapish) 30 amp forward/reverse RC car brushless ESC’s for this build, so I’m having my Nerd friend Rion design a PCB set up and write some code for it.
- Ianth3impler
Re: Scout Mk1
It needs to be forward and reverse.Oddmar wrote:https://www.ebay.com/p/22006058790?iid=274115919207Ianth3impler wrote: In the mean time I have not found any viable (cheapish) 30 amp forward/reverse RC car brushless ESC’s for this build, so I’m having my Nerd friend Rion design a PCB set up and write some code for it.
- Ianth3impler
Re: Scout Mk1
Took a break last week, had to wait for some parts to come in. Tried to cast the flange a few days ago but ended up running into a time crunch and wasn’t able to pour. I was able to CNC out the viewing port out of .25 inch lexan after a few mistakes. I am currently in the process of making the water tight through hull connections, designing LED fixtures, and the electronics tray. I just knocked out the battery set up last night. Here are some pictures.
- making a T-1000
- casting.jpg (38.61 KiB) Viewed 8970 times
- printed a housing for the RPI3 and Pixhawk
- pix.jpg (37.85 KiB) Viewed 8970 times
- CNC.jpg (29.83 KiB) Viewed 8970 times
- cnc1.jpg (31.05 KiB) Viewed 8970 times
- went with a 4S 12900mah battery design
- battery box 23.jpg (42.11 KiB) Viewed 8970 times
- battery box.jpg (31.39 KiB) Viewed 8970 times
- Ianth3impler
Re: Scout Mk1
New update for today: I cut the aft pressure hull bulkhead out of carbon fiber plate. Still learning tolerance measurements for CNCing, my machines could be a couple of blonde ones off. So when CAD says the hole is going to be 12.67mm the machine gives me 12.44 after the cut. Still a work in progress, so I ordered 13mm drill bits to finish the main bulkhead holes. The bulkhead will be comprised of 3 3D printed parts that just hold the connectors in place to be completely submerged in epoxy hopefully granting complete water tightness.
- PH2.jpg (84 KiB) Viewed 8966 times
- PH1.jpg (69.03 KiB) Viewed 8966 times
- PH.jpg (47.49 KiB) Viewed 8966 times
- PH3.jpg (35.86 KiB) Viewed 8966 times
- wt4.jpg (70.42 KiB) Viewed 8966 times
Re: Scout Mk1
nice work and progress.
Re: Scout Mk1
Sorry, apparently that seller put keywords in that messed up my search. I have seen brushless ESC's out there cheap though, just search.
Re: Scout Mk1
I've just ordered one of these-
https://www.ebay.co.uk/itm/Two-way-Brus ... 2749.l2649
I'm hoping it does what it says.
I'm also looking into flashing a single direction ESC with firmware to make it bidirectional.
Hope that helps you.
- Ianth3impler
Re: Scout Mk1
Did you ever start again on your ROV? I just looked through your build from 2011.fryslan76 wrote:nice work and progress.
- Ianth3impler
Re: Scout Mk1
I ordered BLheli s32 35A drone ESC's. hoping to do the same with reflashing to make it bidirectional, I'll try to get that done this weekend. I've been following your new posts, and I'm hoping more people get involved in building ROVs this year. I see a lot of old information on here and would love to see new peoples builds. I would like to point out the tiny drone ESCs are some kind of black magic, I did some tests a few months ago with one of my large quadcopter set ups. I spun a 16 inch prop on a 380kv motor with a 4S lipo balls to the wall full tilt for 10 minutes and the tiny 40 amp ESC I had hooked up wasn't even hot!bigbadbob wrote:I've just ordered one of these-
