deep ROV
greenkarson
deep ROV
Here is my first ROV project. Hoping to be able to reach 500'. Every thing is slowly coming together. Heres a few pics of where Im at now in the contruction phase.
- DSCF1272.JPG (185.34 KiB) Viewed 14727 times
- DSCF1270.JPG (190.28 KiB) Viewed 14727 times
- DSCF1268.JPG (196.89 KiB) Viewed 14727 times
- DSCF1267.JPG (198.8 KiB) Viewed 14727 times
- DSCF1266.JPG (197.1 KiB) Viewed 14727 times
- DSCF1265.JPG (187.67 KiB) Viewed 14727 times
- DSCF1264.JPG (190.49 KiB) Viewed 14727 times
- DSCF1261.JPG (190.35 KiB) Viewed 14727 times
- DSCF1260.JPG (196.44 KiB) Viewed 14727 times
greenkarson
Re: deep ROV
The ROV will have two motorcycle style 12 volt batteries onboard. The 2 holes in the back cap are for leads for charging the batteries with out having to remove everything to get at them. Just open the front plate to let the batteries vent during the charging process. The inner collar in the head light is to hold the lexan. Which will be epoxyed into place. There will be lexan over the two camera windows as well. The bigger hole is for the cctv live feed camera and the offset window is for the hd video camera that will be recording.
- SoakedinVancouver
Re: deep ROV
Ooooh this is going to look good! Full metal jacket, you make my pvc heart sink!
Re: deep ROV
Is that powder coating on the body?
greenkarson
Re: deep ROV
Thanks. Thats just a quick coat of primer to prevent anything from rusting during the build stage
soulreaper
Re: deep ROV
Looks good!!!, keep the build pictures coming.
greenkarson
Re: deep ROV
Still plugging along. Making some good progress. Most of the metal work is done. Lenses are all in place epoxed and sealed.
- DSCF2137 [640x480].JPG (64.23 KiB) Viewed 14389 times
- DSCF2136 [640x480].JPG (59.48 KiB) Viewed 14389 times
Re: deep ROV
WOW
Impressive.... can't wait to see how this one turns out.
greenkarson
Re: deep ROV
Started the electronics! finally! Got all the relays wired in and working nicely. And batteries mounted. Hard to tell in the pic but there are two 5 amphour batteries under all those relays and wires. The relays work nicely through the 500' teather. Well back to work.
- DSCF2149 [640x480].JPG (88.68 KiB) Viewed 14308 times
- DSCF2147 [640x480].JPG (77.76 KiB) Viewed 14308 times
greenkarson
Re: deep ROV
Had to make some changes to the floats after adding all the electronic and batteries.
- DSCF2220 [640x480].JPG (47.85 KiB) Viewed 14213 times
