TigerShark ROV for exploring Puget Sound
TigerShark
Re: TigerShark ROV for exploring Puget Sound
Post by TigerShark »
Here are some pictures from the test and as I work to get all the electronics cleaned up.
I am adding a solid state relay to turn the batteries on and off. When the tether is shut down the relay is off.
salona
Post by salona »
TigerShark wrote:Here are some pictures from the test and as I work to get all the electronics cleaned up.
Hello, I am using exactly the same Hobbyking ESC's as you have but I'm struggling to get the Arduino code correct for arming the ESC's. All I get is a continuous cycle of 4 beeps and the Hobbyking documentation for that particular ESC's is not much help at all. Would it be possible for you to share your code so that I can see where I might be going wrong?
TigerShark
Did you program the ESCs with a programming card or manually? That could be an issue. Also you might test it with a servo instead to make sure it is working up to that point.
Here is my bottomside code:
//Bottomside ROV Software
//Created 06/30/13 by Nick S.
//Last Modified 11/30/13 1503hrs
//Released into the Public Domain
//Thanks to Bill Porter for his Easy Transfer Serial Library
//-----libraries------------------------
#include <Servo.h>
#include <EasyTransfer.h>
EasyTransfer ETOut;
EasyTransfer ETIn;
//-----rs-422/485 com receiver setup-----
#define SSerialTxControl 8 //RS485 Direction control
#define RS485Transmit HIGH
#define RS485Receive LOW
struct rovData
int motor1;
int motor2;
int motor3;
int motor4;
int relay1;
int relay2;
int servo1;
int servo2;
boolean homeCamera;
int motorSpeed;
}data;
struct SensorData
int Temperature;
int Pressure;
}Sensor;
//----------define pin variables----------
int motorPin1 = 2; //Left
int motorPin2 = 3; //Right
int motorPin3 = 4; //Verticals
int motorPin4 = 5; //Verticals
int EnableSensor =6; //TEST ONLY!
//int motorPin5 = 6;
//int motorPin6 = 7;
int relayPin1 =12;// A2; //Accessory 1
int relayPin2 =13; //Accessory 2
boolean relay_1 = false;
boolean relay_2 = false;
int servoPin1 = 11;//A0; //Tilt
int servoPin2 = 10;//A1; //Pan
int ledPin = 9; //Com status pin
int pinSensor=7;// blinks while reading sensors **TEST purposes
//*************Sensors******************
boolean bEnableSensor=true;;
int pinPressureSensor=0;
int pinTemperature=1;
//int PressureSensor;
//int Temperature;
//---------------define value variables-------
int servo1value = 1500;
int servo2value = 1500;
boolean lostCom = false;
int neutral = 1500;
int motorMin = 1000;
int motorMax = 2000;
int ServoNeutral = 90;
Servo Motor1;
Servo Motor2;
Servo Motor3;
Servo Motor4;
//Servo Motor5;
//Servo Motor6;
Servo Servo1;
Servo Servo2;
int gear = 0;
//--------Com led blink variables-----------
int ledState = LOW;
unsigned long previousMillis = 0;
unsigned long interval = 500;
unsigned long lastComCheck = 0;
unsigned long lastComInterval = 1500;
unsigned long last2 = 0;
unsigned long interval2 = 100;
unsigned long current2;
void setup()
//start serial communication
pinMode(SSerialTxControl, OUTPUT);
pinMode(EnableSensor,INPUT);
bEnableSensor=digitalRead(EnableSensor);
digitalWrite(SSerialTxControl, RS485Receive); // Init Transceiver
Serial.begin(57600);
ETOut.begin(details(Sensor), &Serial);
ETIn.begin(details(data),&Serial);
//set I/O state
// pinMode(TxEnable,OUTPUT);
pinMode(relayPin1, OUTPUT);
pinMode(relayPin2, OUTPUT);
digitalWrite(relayPin1, LOW);
digitalWrite(relayPin2, LOW);
pinMode(ledPin, OUTPUT);
//attach servos
Servo1.attach(servoPin1);
Servo2.attach(servoPin2);
Servo1.writeMicroseconds(neutral);
Servo2.writeMicroseconds(neutral);
//attach ESC's
Motor1.attach(motorPin1);
Motor2.attach(motorPin2);
Motor3.attach(motorPin3);
Motor4.attach(motorPin4);
//Motor5.attach(motorPin5);
//Motor6.attach(motorPin6);
Motor1.writeMicroseconds(neutral);
Motor2.writeMicroseconds(neutral);
Motor3.writeMicroseconds(neutral);
Motor4.writeMicroseconds(neutral);
//Motor5.writeMicroseconds(neutral);
//Motor6.writeMicroseconds(neutral);
//*************Sensors*********************
pinMode(pinSensor,OUTPUT);
digitalWrite(pinSensor,LOW);
data.homeCamera = false;
void loop()
//ReadSensors();
//start com led timing variables
current2 = millis();
unsigned long currentMillis = millis();
//check for incoming serial data
digitalWrite(SSerialTxControl, RS485Receive); // Disable RS485 Transmit
if(ETIn.receiveData())
lastComCheck = millis();
interval = 1000;
lostCom = false;
processData();
// if(bEnableSensor==true){ReadSensors();}
ReadSensors();
//check for a break in communication
if(millis() - lastComCheck > 1000)
interval = 100;
rovSafe(); //set everything to safe values
//set com led blink rate
if(currentMillis - previousMillis > interval)
previousMillis = currentMillis;
if(ledState == LOW)
ledState = HIGH;
else
ledState = LOW;
digitalWrite(ledPin, ledState);
inline void rovSafe() //if com is lost or ROV is disabled then set everything to "safe" state
inline void processData()
//motor1 - left
if(data.motor1 > 150 || data.motor1 < 110) //if values are not in neutral range
data.motor1 = map(data.motor1, 0, 255, 1000, 2000); //map values from PS2 range to servo range for good speed control
else
data.motor1 = neutral; //if values are in neutral range set output to neutral
//motor2 - right
if(data.motor2 > 150 || data.motor2 < 110)
data.motor2 = map(data.motor2, 0, 255, 1000, 2000);
else
data.motor2 = neutral;
//motor3 - verticals
if(data.motor3 == 1)
data.motor3 = 2000;
else if(data.motor3 == 2)
data.motor3 = 1000;
else67
data.motor4 = 2000;
else if(data.motor4 == 2)
data.motor4 = 1000;
else
data.motor4 = neutral;
//Servo1 - tilt
if(data.servo1 == 1)
servo1value = (servo1value + 3);
if(data.servo1 == 2)
servo1value = (servo1value - 3);
if(data.homeCamera == true)
servo1value = ServoNeutral;
Servo1.write(servo1value);
//Servo2 - pan
if(data.servo2 == 1)
servo2value = servo2value + 3;
if(data.servo2 == 2)
servo2value = servo2value - 3;
servo2value = ServoNeutral;
Servo2.write(servo2value);
if(data.relay1 == 1 && relay_1 == false) //relay 1
digitalWrite(relayPin1, HIGH); //-watchdog loop so that the pin does no flicker
relay_1 = true;
else if(data.relay1 == 0)
relay_1 = false;
if(data.relay2 == 1 && relay_2 == false) //relay 2
digitalWrite(relayPin2, HIGH);
relay_2 = true;
else if(data.relay2 == 0)
relay_2 = false;
//Gear Speed Select
if(data.motorSpeed == 1)
motorMin = 1300;
motorMax = 1700;
if(data.motorSpeed == 2)
motorMin = 1150;
motorMax = 1850;
if(data.motorSpeed == 3)
motorMin = 1000;
motorMax = 2000;
//Write motor values to ESC's
data.motor1 = constrain(data.motor1, motorMin, motorMax);
data.motor2 = constrain(data.motor2, motorMin, motorMax);
data.motor3 = constrain(data.motor3, motorMin, motorMax);
data.motor4 = constrain(data.motor4, motorMin, motorMax);
//data.motor1 = constrain(data.motor1, motorMin, motorMax);
Motor1.writeMicroseconds(data.motor1);
Motor2.writeMicroseconds(data.motor2);
Motor3.writeMicroseconds(data.motor3);
Motor4.writeMicroseconds(data.motor4);
//Motor5.writeMicroseconds(data.motor5);
//Motor6.writeMicroseconds(data.motor6);
void ReadSensors()
{ digitalWrite(pinSensor,HIGH);
Sensor.Pressure=analogRead(pinPressureSensor);
delay(2);
Sensor.Temperature=analogRead(pinTemperature);
delay(2);
/* Serial.print("ROVPress:");
Serial.print(analogRead(pinPressureSensor));
Serial.print(" ROVTemp:");
Serial.println(Sensor.Temperature);
digitalWrite(SSerialTxControl, RS485Transmit); // Enable RS485 Transmit
ETOut.sendData();
// delay(30);
TigerShark
The latest video. This was a test in a livestock water tank at our last Kitsap CREATE meeting.
