Starting 3D CAD? Give Autodesk 123D Design a try!
Place to discuss CAD and to share Files (zipped)
NCUWI
Post by NCUWI »
I needed a cheap and simple 3D CAD app to rough out a design for a new ROV and decided to give Autodesk's "123D Design" a try ( http://www.123dapp.com/design ). I have to say, it is much better than I expected! The tool set is pretty minimal, but so far I've had no problem creating any surface or object I've needed to. Its import / export capabilities are pretty meager, but I've managed to work around it so far. I haven't sent any designs out for fabrication yet, so hopefully it works as well as I hope.
Bindo
Re: Starting 3D CAD? Give Autodesk 123D Design a try!
Post by Bindo »
Thanks for the tip,
getting a feel for it after playing for a few days, designed some endcaps 8-) 8-)
NCUWI
Post by NCUWI »
@Bindo - Nice! I'm finding 123D Design to be surprisingly powerful. Although it doesn't have all the tools I'm used to, I find that I can do most things one way or the other.
samworthington
Post by samworthington »
Autodesk Fusion 360 http://www.autodesk.co.uk/products/fusion-360/overview and PTC Creo Elements Direct http://www.ptc.com/product/creo/element ... ng/express are also worth a look.
Sam
aDub
Post by aDub »
One of the nice things about 360 is the ease of sharing work between a group. Collaboration is really easy.
It also easy to import hardware drawings from mcMaster-Carr, nuts, bolts, pipes, etc. nearly everything in the catalogue has a CAD file. This frees you up from the mundane stuff. For a free app it's pretty good with sheet metal, cam, rendering, etc. The learning curve is pretty shallow, and to be fair it knocks sketch-up into a cocked hat.
