I started my experimental ROV by funding for three Blue Robotics T100 Thrusters (https://www.bluerobotics.com/store/thru ... -thruster/) with built-in ESCs when they started their Kickstarter Project early last year.
By the time that the T100 Thrusters had arrived earlier this year I had already decided to add a fourth Thruster and Blue Robotics had begun to offer a selection of WTCs on their website (https://www.bluerobotics.com/store/). So I ordered a fourth Thruster and two 4" diameter WTCs (https://www.bluerobotics.com/store/wate ... e4-asm-r1/) configured with clear End Caps on the front and 10 hole End Caps on the rear and the necessary cable penetrators (https://www.bluerobotics.com/store/part ... r-10-25-a/).
I chose to use two WTCs so that besides the navigation controller WTC I would have a second WTC to hold the LiPo batteries as I had decide not to try and power the ROV from the surface which just adds weight to the ROV tether. Therefore the tether would just carry communication and video lines and be very light weight.
Below are some pictures of the ROV hardware:
The T100 Thruster ESC can be controlled by either PWM or I2C signals.
I chose one blank acrylic End Cap (front of WTC) and one with 10 holes for power, Vent Cap, and instrumentation wiring penetrations (rear of WTC).
Two of the O-rings are used to seal the O-ring Flanges in the WTC tube while the third O-ring is used to seal the acrylic End Caps to the face of the O-ring Flanges.
The blank Cable Penetrators can be used to either make custom penetrators for cables other than 6mm dia or to block off unused holes in the acrylic End Plates.
SSN626B/TCIII
