Sharing some basic Solidworks files.
Place to discuss CAD and to share Files (zipped)
These are just some Solidworks files of standard Bilge Pump Thrusters Parts, PVC pipe, and some Fittings that I am sharing. Pretty basic stuff if you know CAD but these might help someone save some time in designing their Rov in the future so I figured what the hell. Files are zipped but are all in .SLDPRT format. There are a lot of PVC manufactures out there but these are about 99% correct as far as most of the outside dimensions go for the parts I had on hand.
Re: Sharing some basic Solidworks files.
Thruster Parts
(Pump Tabs have been trimmed)
(Prop is just for looks. 50mm Dimension is correct but blade shape is not correct)
Assem Thruster with Mount.jpg (55.81 KiB) Viewed 265944 times
Assembled Parts
Mayfair 750 GPH Pump.jpg (57.15 KiB) Viewed 265944 times
Mayfair Pump 750.zip
(317.79 KiB) Downloaded 6495 times
Pipe Clamp One and Half Inch.jpg (52.93 KiB) Viewed 265944 times
Pipe Clamp One and Half Inch.zip
(460.11 KiB) Downloaded 6696 times
PVC One and Half Inch Pipe Motor Mount.jpg (38.65 KiB) Viewed 265944 times
PVC One and Half Inch Pipe Motor Mount.zip
(55.72 KiB) Downloaded 6131 times
Prop Adapter.jpg (49.74 KiB) Viewed 265944 times
Prop Adaptor.zip
(529.72 KiB) Downloaded 6992 times
Nut 4mm.jpg (41.48 KiB) Viewed 265944 times
Nut 4mm.zip
(192.33 KiB) Downloaded 6591 times
Prop 50mm.jpg (41.77 KiB) Viewed 265944 times
Prop 50mm.zip
(282.85 KiB) Downloaded 6258 times
1/2" PVC Pipe & Fittings
(The look of the 1/2" 90 degree fitting is off a little but still useable.)
PVC Half Inch Pipe.jpg (36.99 KiB) Viewed 265944 times
PVC Half Inch Pipe.zip
(50.65 KiB) Downloaded 5971 times
PVC Half Inch T.jpg (39.67 KiB) Viewed 265944 times
PVC Half Inch T.zip
(164.17 KiB) Downloaded 6463 times
PVC One and Half Inch End Cap Round.jpg (35.12 KiB) Viewed 265944 times
PVC Half Inch End Cap Round.zip
(116.2 KiB) Downloaded 6385 times
PVC One and Half Inch End Cap Flat.jpg (34.12 KiB) Viewed 265944 times
PVC Half Inch End Cap Flat.zip
(84.28 KiB) Downloaded 6019 times
PVC Half Inch Coupler.jpg (42.08 KiB) Viewed 265944 times
PVC Half Inch Coupler.zip
(100.46 KiB) Downloaded 5949 times
PVC Half Inch 90.jpg (39.99 KiB) Viewed 265944 times
PVC Half Inch 90.zip
(159.76 KiB) Downloaded 6307 times
More various Pipe and Fittings
PVC Two Inch End Cap Round.jpg (38.97 KiB) Viewed 265944 times
PVC Two Inch End Cap Round.zip
(141.07 KiB) Downloaded 6258 times
PVC Two Inch Pipe.jpg (38.99 KiB) Viewed 265944 times
PVC Two Inch Pipe.zip
(61.25 KiB) Downloaded 6253 times
PVC Three Quarter Inch Pipe.jpg (37.76 KiB) Viewed 265944 times
PVC Three Quarter Inch Pipe.zip
(50.72 KiB) Downloaded 6147 times
PVC One and Half Inch Pipe.jpg (41.22 KiB) Viewed 265944 times
PVC One and Half Inch Pipe.zip
(58.84 KiB) Downloaded 6035 times
PVC One Inch T.jpg (42.61 KiB) Viewed 265944 times
PVC One Inch T.zip
(155.19 KiB) Downloaded 6106 times
PVC One Inch Pipe.jpg (39.11 KiB) Viewed 265944 times
PVC One Inch Pipe.zip
(57.02 KiB) Downloaded 6091 times
nirali31
Post by nirali31 »
Got your basic Solidworks files . It was much needed.
lasikakawade
Post by lasikakawade »
Thanks for this great post :) well done
Ramjet
Post by Ramjet »
I've added some DXF files of the bilge pump in case that can help with your designs.
Cheers,
Ramjet.
Bilge Pump.zip
(41.37 KiB) Downloaded 5394 times
Bilge Pump 2.JPG (122.39 KiB) Viewed 259771 times
